A/C blowing warm air
2006 CHRYSLER PT CRUISER
72,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
BIGFRANK
The interior fan stopped working. I replaced it with a new one which works great. The compressor works great. The low side is 20 lbs and when the compressor cuts in its 44lbs. The low-side pipe gets cold. The inside gages are set high fan. Cools to max and the air light on and recycle air on. But the air blowing is not cold.
Apr 1, 2022 at 11:02 AM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
What are the outside temperatures when you get 44lbs on the low side? Also, do you know the high side pressures?
Do me a favor. Take a look through this link and let me know if anything is helpful.
If possible, let me know the ambient temperatures and the high side pressures.
Apr 1, 2022 at 9:49 PM
