no air conditioner at the front vents
53,000 MILES • 4.6L • V8 • RWD • AUTOMATIC
JOHN V KNOX
no cold air blowing at the front vent all the other vents work.
Jul 16, 2016 at 2:53 PM
HMAC300
  • 48,601 POSTS
try pulling HVAC fuse inside car for sixty seconds with key on it may reset actuators then check to see if actuator is getting power. if no power have it scanned for codes a mechanic will need to do it.
Jul 17, 2016 at 1:40 AM
JOHN V KNOX
turned key to on powered up air conditioner set to max air conditioner unplugged floor/panel actuator several time, the third time it calibrated itself, and plows air out of front vents, fixed for now, someone has been to this actuator before, it is a used car to me. the plug no longer has the red safety clip on it.
Jul 17, 2016 at 4:41 AM
JOHN V KNOX
turned key to on powered up air conditioner set to max air conditioner unplugged floor/panel actuator several time, the third time it calibrated itself, and plows air out of front vents, fixed for now, someone has been to this actuator before. it is a used car to me, the plug no longer has the red safety clip on it. part your looking for will be left hand panel/floor 19E616. see image.
Jul 17, 2016 at 4:44 AM
HMAC300
  • 48,601 POSTS
It may need to be scanned for codes if it happens again. it may have a bad connection on it.
Jul 17, 2016 at 6:17 AM
