Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Saturn
Ion
General
Noises
Grind
No fifth gear
2005 SATURN ION
183,000 MILES • 2.2L • 4 CYL • FWD • MANUAL
NICKDIONNE2008
MEMBER
First through fourth shift fine, but it will not go into fifth it just grinds. any idea what it could be? linkage?
Jun 25, 2017 at 5:31 PM
SATURNTECH9
Experienced Mechanic
If you turn the car off will it go into the gear it grinds into with it running?
Jun 27, 2017 at 4:12 AM
SATURNTECH9
If someone is watching at the transmission while your shifting is the cable and linkage moving?
Jun 27, 2017 at 4:13 AM
NICKDIONNE2008
MEMBER
Yes linkage is moving and when car is off it seems like it goes into 5th
Jun 27, 2017 at 11:01 AM
SATURNTECH9
Then most likely you have a bad 5th gear synchro blocker ring.Thats what let's the gears change without grinding.
Jun 27, 2017 at 11:27 AM
SATURNTECH9
I have had a few of those transmissions apart that were grinding into only certain gears and that's what is was.
Jun 27, 2017 at 11:28 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
