2004 Nissan Xterra Speedometer Out
GS57143
I have an automatic 2004 Nissan Xterra. Both the Speedometer and Odometer stopped working, and when I get up around 4th gear(a guess) the car acts as if it's in neutral when I hit 2000rpm. If I let the car drop below 2000rpm I can accelerate, but not above 2000rpm. I'm guessing my max speed under this condition is 50mph. Does anyone know what's going on?
Sep 4, 2007 at 7:43 AM
  • 75,988 POSTS
[quote:17591f4e56="gs57143"]I have an automatic 2004 Nissan Xterra. Both the Speedometer and Odometer stopped working, and when I get up around 4th gear(a guess) the car acts as if it's in neutral when I hit 2000rpm. If I let the car drop below 2000rpm I can accelerate, but not above 2000rpm. I'm guessing my max speed under this condition is 50mph. Does anyone know what's going on?[/quote:17591f4e56]
Sounds like the Vehicle Speed Sensor
Sep 4, 2007 at 7:48 AM
Suggested Repair
Inspect and test the vehicle speed sensor, since a failed sensor can stop the speedometer and odometer and cause the transmission to shift incorrectly.
Conversation Summary
The owner of a 2004 Nissan Xterra reports that the speedometer and odometer stopped working and the automatic transmission acts as if it is in neutral near 2000 rpm, limiting speed to about 50 mph. The expert says the symptoms sound like a faulty vehicle speed sensor.
