Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Xterra
Interior
Instrument Cluster
Gauges
Engine Temperature
2002 Nissan Xterra Temp guage it gets higher than normal.
2002 NISSAN XTERRA
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
NISSAN 02
MEMBER
1 POST
Temp guage it gets higher than normal when AC is on?
Jun 24, 2010 at 4:25 PM
Experienced Mechanic
Check if the condenser fan is coming on also test the engine coolant temperature sensor or the temperature gauge sending unit switch if it has one.
Check the coolant level
Jun 24, 2010 at 4:47 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
