Smell of Antifreeze
XTERRA OWNER
2004 Nissan Xterra. I am noticing a faint smell of antifreeze, mostly when it is a warm temperature outside. Have checked the engine and find no leaks or wetness anywhere. Any idea what it could be?
May 25, 2006 at 7:34 AM
ERNIE ERKMAN
this is where you are probably smelling it from which may mean you radiator cap is weak and needs replacing.
May 25, 2006 at 11:57 AM
FSCHARLIE
  • 5 POSTS
If you can smell the antifreeze inside the vehicle it may be a leaking heater core. turn on the heater with the temp set high and see if the smell gets worse.
May 26, 2006 at 10:54 AM
