2006 Nissan Xterra Charge warning light
2006 NISSAN XTERRA
66,000 MILES • 6 CYL • 4WD • AUTOMATIC
NAKAYLA09
Charge warning light came on today, manual states that the generator belt could be loose, broken or missing. Also difficult to steer. Are the two related? What is a fair price to repair
Mar 13, 2010 at 8:08 AM
CARADIODOC
  • 34,381 POSTS
How did you get so lucky? Charging system problems can be expensive to repair, but in your case, you provided the dandy observation about the hard steering. Without that clue we would have sent you totally down the wrong road.
The drive belt broke or fell off for the generator and power steeing pump. Unless it's really hard to access, this is less than a 100 dollar job. Depending on the type of belt, a V-belt generally costs less than 20 bucks, and a flat, ribbed serpentine belt is usually less than 50 bucks. Time to install them can get up to an hour if other belts must be removed first or if it's hard to get to some of the pullies.
Watch that the engine doesn't overheat on the way to the repair shop or home. The water pump might be driven by the same belt.
caradiodoc
Mar 13, 2010 at 8:21 AM
NAKAYLA09
Great to hear today is my lucky day!!! Thanks for you quick reply.
Mar 13, 2010 at 8:37 AM
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
Mar 15, 2010 at 9:50 AM
