2005 Nissan Xterra Ninja Hauler making a fuss
2005 NISSAN XTERRA
30,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLETE34
My Xterra is making a squealing noise from the belt. I applied belt dressing to no avail. It sounds like it's coming from the area of the power steering pump but does not change in pitch when I turn the front wheels, only with the speed of the engine. It sat for about months before I bought it. Maybe a seized bering?
Jan 21, 2009 at 5:48 AM
2CARPRO JACK
  • 11,533 POSTS
Best way to find out would be to remove the belts one at a time until the noise goes awaay, that will tell you which one it is.At that mileage it shouldnt need a new belt, but it could be a bearing failure like you said.Be sure to use carb cleaner to get all the belt dressing off the pulleys
Jan 21, 2009 at 8:30 AM
