2005 Nissan Xterra fuel delivery system
2005 NISSAN XTERRA
71,000 MILES • 6 CYL • 2WD • AUTOMATIC
DBURK
My 4.0 V6 2005 Nissan Xterra has what seems to be a common problem for owners. The fuel guage was incorrect. I then change the fuel pump module including the fuel level sensor and the sender. My sparks are good and my fuel injectors are firing. I have determined that it must be in the fuel delivery. I want to check for blockage in the fuel filter but cannot determine if one even exists in my Year/Make/Model. Also I want to know what is the easiest way to check fuel pressure since there is no service port on the fuel rail.
Jul 23, 2010 at 4:05 PM
NOTE: The Fuel Filter for this vehicle is a 'Maintenance-Free item', and does not require routine service.
https://images.2carpros.com/forum/automotive_pictures/12900_ff_14.gif
Jul 23, 2010 at 6:15 PM
