2004 Nissan Xterra Clutch will not come on right
46,716 MILES • 6 CYL • 2WD • AUTOMATIC
MIKEICE57
I ran a wire from battery it did make clutch come on for the AC ,the relay is working, I want the clutch to work without having to use wire from battery, have any suggestions.Thanks,
Mike
Jul 13, 2008 at 5:51 AM
KHLOW2008
  • 41,812 POSTS
Hi Mike,
You should use the reply to question link when continuing on the same problem so that whoever was attending to you can response when notifucation is received.
Remove relay and test for power supply. There should be 1 powered terminal at all times and 2 when engine is running. Jump the powered terminal wiith the terminal connecting to the compressor and see if the compressor works.
If yes and relay seems to click when plugged in, replace the relay.
If no, check for broken wire to compressor.
Jul 20, 2008 at 12:52 AM
