2003 Nissan Xterra WHITE SMOKE
2003 NISSAN XTERRA
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
ALTHATJAZ
Heavy white somke comes out of the exhaust when starting the vehilce. what could it be and what can I do to repair the situation. Thank You
Oct 9, 2008 at 8:55 AM
White smoke is an indication of coolant being burn in the combustion chamber-could mean blown headgasket/ cracked head or block.
Get block and pressure tested
Oct 9, 2008 at 9:08 AM
ALTHATJAZ
There are two hoses through where cooalnt run through that are worn down. Is it possible for them to be leaking onto the engine cause the white exhaust smoke.
Oct 9, 2008 at 10:16 AM
You can try the two hoses -if it continues once again the way to tell is to get block and pressure tested.
Oct 10, 2008 at 1:12 AM
