2003 Nissan Xterra WHITE SMOKE
ALTHATJAZ
  • 2003 NISSAN XTERRA
  • 4 CYL
  • 110,000 MILES
Heavy white somke comes out of the exhaust when starting the vehilce. What could it be and what can I do to repair the situation. Thank You
Thursday, October 9th, 2008 AT 3:55 PM
White smoke is an indication of coolant being burn in the combustion chamber-could mean blown headgasket/ cracked head or block.
Get block and pressure tested
Thursday, October 9th, 2008 AT 4:08 PM
ALTHATJAZ
There are two hoses through where cooalnt run through that are worn down. Is it possible for them to be leaking onto the engine cause the white exhaust smoke.
Thursday, October 9th, 2008 AT 5:16 PM
You can try the two hoses -if it continues once again the way to tell is to get block and pressure tested.
Friday, October 10th, 2008 AT 8:12 AM
