2003 Nissan Xterra no fluid to front calipers
2003 NISSAN XTERRA
122,000 MILES • 6 CYL • 2WD • AUTOMATIC
HAGANADAM
just changed the brakes and when bleeding discovered no fluid to left front, and very little to right front. very soft pedal. pressure bled and no change. checked master cylinder, seems ok. check hoses and they seem fine as well. what's next? please advise. any help is greatly appreciated.
thank you,
adam
Nov 30, 2009 at 2:52 PM
  • 31,937 POSTS
Hi there, i would be suspecting a faulty master cylinder, but first try re bleeding then clamp off the 3 brake hoses, with line clamps, the pedal should be high and hard, let me know that it is like.
Mark (mhpautos)
Nov 30, 2009 at 2:56 PM
