Where is the PCM?
82,000 MILES • 4 CYL • 2WD • MANUAL
RATAJSKI
I recently got a Chilton and my check engine light is on. I was looking up information about why the light may be on. There is a reference to being able to determine the code by using a diagnostic tool on the PCM, but nowhere in the Chilton does it explain where this PCM is located. Can you tell me where I would find this thing? Thanks.
Feb 23, 2008 at 1:35 PM
BMRFIXIT
  • 19,053 POSTS
use an OBDII reader, if that wont communicate some Nissans in the early 2000's still used their proprietary connector located next to the fuse block
https://images.2carpros.com/forum/automotive_pictures/99387_ecm_nissan_1.jpg
Feb 23, 2008 at 2:39 PM
