Electrical problem
2000 Nissan Xterra 6 cyl Two Wheel Drive Automatic
I have a Nissan Xterra that was going fine and then it started running rough. After a short distance (about 1 kilometer) it stopped and has not gone since I have tried the ignition and there is no spark at the spark plugs. Also put a diod across the injactor and on cranking there is no pulse.
I have tried another ECU and it has had another crank sencor fitted.
Put a scanner on it and there are no faults showing When I crank with the distributor wiring unplugged it shows a cam sencor fault. Connected all shows O.k
It has a factory emobaliser and the light on the dash flashes when the key is removed and when the ignition is turned on it goes out.
Any sugestions would be appreciated.
NOEL.
Could the distributor be at fault.
NOEL.
Oct 29, 2010 at 4:45 PM
