ABS LIGHT ON
KEMPSA21
After getting my oil changed, my ABS light has come one. I called the place that performed it, and they said that it could be brake dust on the sensors?
Does anyone knon anything about ABS system?? Also, can it hurt anything to drive with ABS light on?
Jan 10, 2006 at 2:08 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the warning identified and the brake system checked, including fluid level and appropriate ABS diagnostics. If a brake-system warning accompanies a low pedal, fluid leak or impaired braking, arrange recovery.
Guidance references and applicability
Source: This question and its visible discussion, including any clearly labeled editorial corrections. Owner reports are distinguished from other participants' experiences. Follow-up guidance is not a confirmed diagnosis.
Read the replies · Discussion summary and reported outcome
MAINIAC
It turned out the fluid was WAY low, most oil places wont touch your brake fluid. Have you checked the fluid level?
This video will help you get the codes to see whats up.
https://youtu.be/rTtAnsOlZU4
Jan 16, 2006 at 12:36 PM
Discussion summary
ABS LIGHT ON
The owner reported an ABS warning appearing after an oil change and asked whether driving was safe. A reply mentioned low brake fluid and suggested obtaining ABS codes.
Reported outcome: The original owner did not report a diagnosis or repair.
The reply's low-fluid account was not a confirmed measurement on this vehicle. Timing after an oil change did not establish the cause.
Read the original discussion
