2007 Nissan X-Trail car problems
50,000 MILES • 4 CYL • 4WD • AUTOMATIC
JKIDANE
When ever i turn to the right I hear a skidding sound without pressing the brakes. I also hear the same skidding sound when I'm driving straight at low speeds, again without pressing the brakes. i also noticed that my rear tires seem worn on the inside, driverside seems worn on the rightside of tire and the passenger side tire is worn on the left side of tire. your help will be geatly appreciated..
Best regards
Jonathan
Oct 6, 2010 at 7:27 PM
  • 31,937 POSTS
Hi there,
I would start with having a 4 wheel alignment check, you may have to replace the tyres as well, as i can't tell how bad they are , but the primary problem sounds like a chronic misalignment problem, start here.
mark (mhpautos)
Oct 6, 2010 at 9:59 PM
