After engine swap the car will not accelerate past five MPH?
140,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
ROBERMUDEZ
The car had a bad engine, so I got the engine swapped. The car would run fine before engine swap. Now that the engine has been swapped it won't pick up speed. I hold the pedal down and it just doesn’t go above 5 MPH. What could be the problem?
Jun 27, 2023 at 6:46 AM
  • 110,248 POSTS
If you place it in neutral or park, does the engine rev normally? Also, have you scanned for diagnostic trouble codes?
If you haven't checked for codes, that is where I would recommend starting. Actually, I would suggest scanning the can-bus.
CAN stands for controller area network. Basically, the different modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing a code.
Here is a link that explains how it's done:
Also, when it is running, let me know if there are any odd odors from it or sounds.
Jun 27, 2023 at 1:27 PM
