2009 Nissan Versa oil pressure
2009 NISSAN VERSA
2,500 MILES • 4 CYL • 2WD • AUTOMATIC
XX.010101
Oil pressure is too high on my 2009 nissan versa. Every time when I start a car oil filter gasket blows. First thing I checked: oil filter tread. It's not bent. Every time I change filter or fix gasket, it blows in different places. Can anybody help me with this problem?
Nov 25, 2009 at 3:28 PM
  • 31,937 POSTS
Hi there,
The first thing you need to do is get the oil pressure tested with a mechanical gauge, get the readings at cold idle, hot idle and at 1500 RPM hot, i would be thinking you have a faulty oil pressure relief valve,
mark (mhpautos)
Nov 25, 2009 at 3:38 PM
