Nissan Truck Smog Failure High Fuel Use
BILLF106
my truck has passed smog for 2 years in a row, now
it failed, Smog test showed using too much gas. can
you help
Feb 12, 2006 at 10:04 PM
MVANNESSJR
  • 223 POSTS
Click Smog Test Preparation. Second page of that gives great prep examples. Check air filter, spark plugs, and fuel pressure. Fuel filter may have become clogged and the fuel pump is working harder than it should. Fuel injectors may need to be cleaned. Check idle air control, mass air flow sensor, and O2 sensors.
If it's burning a lot of fuel it could be a very simple solution or a combination of a few things. Remember the amount of fuel it uses depends on a few different variables (spark and oxygen).
Feb 12, 2006 at 11:21 PM
Suggested Repair
Check the air filter, spark plugs, and fuel pressure. Inspect for a clogged fuel filter and an overworked fuel pump, clean the fuel injectors if needed, and check the idle air control valve, mass air flow sensor, and oxygen sensors.
Conversation Summary
The owner of a Nissan truck said it failed a smog test for using too much fuel after passing for two years. An expert recommended checking the air filter, spark plugs, fuel pressure, fuel filter, fuel injectors, idle air control, mass air flow sensor, and oxygen sensors, noting that fuel use depends on spark and oxygen.
