91 d21 hardbody. 3-2. egr temp sensor ohm specs?
1991 NISSAN TRUCK
PHOOTBAG
150k miles, 1991 nissan hardbody pickup d21 ( 4 cylinder ) Applying vacuum to the egr at idle makes the engine bogg horribly but not stall. Cylinder balance test while egr is activated at idle; all cylinders react equally. BPT valve is working. Cold, the egr temp sensor ohms at 1mega ohm. With egr activated at idle for about 2 minutes the ohm spec is about 40k. Is this within specification? I am suspecting the egr is actually working but possibly the monitor system is faulty, ie; biased egr temp sensor. Any help would be appreciated. Thanks in advance.
Aug 19, 2007 at 2:46 PM
[quote:f265cb695b="phootbag"]150k miles, 1991 nissan hardbody pickup d21 ( 4 cylinder ) Applying vacuum to the egr at idle makes the engine bogg horribly but not stall. Cylinder balance test while egr is activated at idle; all cylinders react equally. BPT valve is working. Cold, the egr temp sensor ohms at 1mega ohm. With egr activated at idle for about 2 minutes the ohm spec is about 40k. Is this within specification? I am suspecting the egr is actually working but possibly the monitor system is faulty, ie; biased egr temp sensor. Any help would be appreciated. Thanks in advance.[/quote:f265cb695b]
EGR is doing okay the way you check it- plug EGR hose, now take it up to 2K rpms-the vacuum gauge should read vacuum. if it does the EGR is functioning properly.
EGR Temp. sensor when close-should read 3-4volts/open should read0-3volts.
Aug 19, 2007 at 4:51 PM
