1997 Nissan Truck flushing the coolant
95,000 MILES • 4 CYL • 2WD • AUTOMATIC
TONHERES
I recently replaced my radiator. I added water to the new radiator and ran the engine for about 5 minutes then drained the radiator and did this several times. But each time only about 1 gallon drains out with some old fluid. Is this normal? Do I just continue to fill and drain the radiator or is there something I'm missing?
Aug 28, 2008 at 1:24 AM
DOCFIXIT
  • 18,828 POSTS
With engine warm shut off remove bottom radiator hose . After it drains leave off garden hose in rad. start run till clear water . Then let drain connect put in straigt antifreeze then top off with water.
Aug 28, 2008 at 1:36 AM
