1997 Nissan Truck RPM Limit at 2500
JESSEJAMESTH
I have a 97 Nissan 4X4 truck with a 2.4 engine, I have just replaced the engine all new. The problem i have is it will not rev over 2500rpms the truck cranks good and runs good just cuts out when you get to 2500 rpms. feels just like a rev limiter. any help would be great.
Jan 20, 2007 at 3:26 PM
  • 75,988 POSTS
[quote:a548ba9314="jessejamesth"]I have a 97 Nissan 4X4 truck with a 2.4 engine, I have just replaced the engine all new. The problem i have is it will not rev over 2500rpms the truck cranks good and runs good just cuts out when you get to 2500 rpms. feels just like a rev limiter. any help would be great.[/quote:a548ba9314]
JJ
Sounds like the TPS needs initial adjustment-won't hurt to check the AFM
Jan 20, 2007 at 4:43 PM
Suggested Repair
Check and set the initial throttle position sensor (TPS) adjustment, and also inspect the air flow meter (AFM).
Conversation Summary
A 1997 Nissan 4x4 pickup with a newly replaced 2.4 engine starts and runs well but cuts out above about 2500 rpm, similar to a rev limiter. The expert suggested the TPS may need its initial adjustment and that the AFM should also be checked.
