my 93 nissan pickup pulls hard to the left when the brakes are applied hard. i have just recently replaced the brake master cylinder as well as the front brake lines. it was suggested by a local repair shop that the right brake line might be collapsed internally, therby causing the pull to the left front brake.
i have removed the brake pads and greased all the areas recommended. the tires or the brake pads do not appear to be wearing abnormally.
i have also tightened and torqued the bolt connecting the slide rod assebly to the left front wheel.
any thought on what else might be causing the problem?
Jan 7, 2008 at 8:08 AM
