1991 Nissan Truck hard to put into gear
105,000 MILES • 4 CYL • 2WD • MANUAL
JISAACS3
1991 nissan pick up 2wd, manual transmission, it is hard to get it into gear. specially first thing in the morning. after driven for a few miles it does get easier to put into gear. the pedal is soft most of the time as well. This has been going on for about a week.
Oct 28, 2008 at 11:16 AM
  • 31,937 POSTS
Hi there, start with bleeding the clutch and check for any leaks and repair as required, also if it is just for the first few changes, i would check the transmission oil specs, and change the oil to make sure it is correct.
Mark (mhpautos)
Oct 28, 2008 at 12:30 PM
