Engine vibrates a lot at idle.
1986 NISSAN TRUCK
77,000 MILES • 4 CYL • 2WD • MANUAL
KRAZZYKEVIN
My truck (a nissan 720) has the 2.4l Z24 engine with carburetor and lately it idols at around 1200 RPM, which higher than it should I believe, and it intermittently vibrates fairly intensely, enough to shake the stick back and forth and make things shake inside the cabin. It does this every 10 or 15 seconds or so. And if I rev it up then sometimes it drops way low to like 200 RPM and almost dies if I don't give it some gas. I just changed the spark plugs, oil, and air filter, I replaced the OEM filter with a K&N. What might the problem be? Any help is appreciated. Thanks.
Aug 27, 2009 at 5:27 AM
  • 55,432 POSTS
This sounds like you have a vacuum leak somewhere in the engine lets start by following this guide to see what you find.
Please let us know what you find.
Cheers, Ken
Feb 14, 2018 at 12:54 PM
MARK C
I wanted everyone to know this problem was the gasket under the carburetor had gone bad once I replaced it the truck runs great again.
Feb 14, 2018 at 12:55 PM
