1986 Nissan D 21 Fuel Problem
XPLORIDAHO
I have had the fuel pump replaced already to the tune of $350, still wont start. Will start if I dump gas down the throttle body though. Any help is appreciated. Thanks John
Aug 10, 2007 at 9:14 AM
XPLORIDAHO
The diagnostic code on the computer says that the injectors have an electrical problem. Any idea what that could be?
Aug 10, 2007 at 11:24 AM
  • 75,988 POSTS
[quote:304fa7390b="xploridaho"]The diagnostic code on the computer says that the injectors have an electrical problem. Any idea what that could be?[/quote:304fa7390b]
At the injector harness on the throttle body disconnect it put a test lite on the red and white wire do you have power?
At the computer connector while connected check for power at pin 114-no power there you have a problem with the computer
Also do a continuity test on the red and white both end disconnected- O reading wire is good and infinite/needle don't move you have an open wire on the red and white. Note do the same with the ground wires black by itself and a black and blue-you should have the same reading with the red and white wire.
Hope this helps
Aug 14, 2007 at 11:53 PM
