1983 Nissan Truck 83 Nissan pick up stalling
RICKY211
  • 1983 NISSAN TRUCK
  • 4 CYL
  • MANUAL
  • 200,000 MILES
I just bought an 83 Nissan pickup. It starts and idles for a few seconds then stalls. If I feather the throttle I can keep it running. If I get it moving by feathering the throttle it will run. It seems to be worse when cold. Thanks in advanced for any help.
Thursday, October 23rd, 2008 AT 12:33 PM
Hi Ricky211 and welcome to 2carpros
Lets start by ensuring that the fuel pump is producing the corrrect fuel pressure by using a fuel pressure gauge-Pressure okay-inspect/clean/test the PCV and EGR valves. Also make sure the air/fuel solenoid valve is operating
Make sure the curb idle speed is correct/the ignition timing and choke plate is opening during initial start up-
Thursday, October 23rd, 2008 AT 1:44 PM
