Code P0605
70,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
GENERALLEE01
hi, i have just change the ECM on my car and after three months i have seen that the problem is not solve and i have done a diagnostic it says p0605.
if you can help me on this.
thanks
Apr 15, 2017 at 7:46 PM
HMAC300
  • 48,601 POSTS
we do not have t hat model in USA, but it is an ECM code and a mechanic should check this out as it may be a connection problem or blown fuse or short. It may also be a can/bus problem which a mechanic can read with his scanner.
Apr 16, 2017 at 1:41 AM
