2004 Nissan Sunny noises is coming from front
2004 NISSAN SUNNY
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
RONEYMATHEW
while running the vehicle . very noise is coming . i checked the under body . the front left side axle bearing side little grease came out . but there is no play . and the tyre also new . so why the sound is coming it is because of the axle or the tyre noise or suspension sound or steering assembly noise which part i should check please help .
Jan 23, 2010 at 4:17 AM
RONEYMATHEW
[quote:8a01e3389c="roneymathew"]Noises problem
2004 Nissan Sunny 4 cyl Two Wheel Drive Automatic 200000 miles
while running the vehicle . very noise is coming . i checked the under body . the front left side axle bearing side little grease came out . but there is no play . and the tyre also new . so why the sound is coming it is because of the axle or the tyre noise or suspension sound or steering assembly noise which part i should check please help .[/quote:8a01e3389c]
