2004 Nissan Sunny Car does not pickup speed occasionally
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
DEVFCW
Occasionally, my car does not pick up speed after a stop at the junction. Stepping on the accelerator simply revs the engine to more than 3000rpm but the car still moves at 10-20km/hr. I've changed the transmission fluid and spark plugs but problem still persists. I've to pull over and restart the engine, and it'll be back to normal.
May 16, 2010 at 3:31 AM
  • 75,988 POSTS
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 22, 2010 at 4:37 PM
