1. Remove fuse for fuel pump (located under the drivers side of the dash).
2. Turn the ignition to the start position for approximately 15 seconds (this will release the fuel pressure).
3. Remove upper and lower portions of rear seat.
4. Remove round fuel pump access panel.
5. Remove fuel pump electrical connector.
6. Remove fuel pump mounting screws.
7. Lift fuel pump assembly from tank.
8. Reverse procedure to reinstall, using a new o-ring and torque fuel pump assembly to 1.4 - 1.9 ft-lb (2 - 2.5 Nm).
SPONSORED LINKS
Sunday, February 21st, 2010 AT 10:09 PM
