1989 Nissan Stanza over heating
1989 NISSAN STANZA
MITCH103309
Engine Cooling problem
1989 Nissan Stanza 4 cyl Front Wheel Drive Manual
I live i alaska my car is over heating but only when it is very cold out .when it is above freezing it works fine but below freezing it over heats and the heater quits blowing hot air also the steam seems like its coming from the top of the engine not the radiator. im wondering if it is just a bad thermostate ???
Dec 7, 2009 at 9:14 PM
Good idea on the thermostat get it replace asap and get back with me if it doesn't work
Dec 7, 2009 at 9:29 PM
MITCH103309
Where is the thermostate located on a 1987 nissan stanza????
Dec 8, 2009 at 11:47 AM
The thermostat housing is located below the alternator and directly across from the lower right side of the radiator(not the lower radiator hose side
Dec 8, 2009 at 11:58 AM
MITCH103309
the clutch pedal has completly gone away it goes to the floor and stays there the fluid is very low i was wondering if i put more fluid how to bleed the air out??????And will that even be the problem???
Dec 8, 2009 at 5:52 PM
