1986 Nissan Stanza Sputtering Engine Trouble
LEFTYGOMEZ0
1986 Nissan Stanza
My 1986 Nissan Stanza was running regularly. I parked it while running errands but when I started her up again, I got about 2 miles down the road when all of a sudden the engine started lagging and sputtering. It was fine until I tried to give her some gas. When I'd accelerate, the engine just wouldn't catch or something for a few seconds, then she'd catch again. I topped up the oil, made sure she had plenty of fuel and the problem has only escalated. At this point, she doesn't have the guts to make it up even a small incline. When I accelerate, the car even cuts out and dies completely. She idles great but I'm at a loss. Any advice would be much appreciated. Thanks!
Jul 14, 2010 at 5:28 PM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 14, 2010 at 8:55 PM
