1990 Nissan Skyline the plenium
170,000 MILES • 6 CYL • 2WD • MANUAL
HADZ01
hi i have a nissan skyline rb20de i have put the engine in after the old one seized and after puting it in and starting it up and puting the heater on hot and full no water will come up to the bleeding nipple its not over heating or anything could it be the water pump. thanks
May 31, 2010 at 1:49 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, how long did you let it run? You say it is not overheating, if it is not overheating then the water pump is working fine, but that will also depend on how long vehicle was run.
Something to check, with engine off and cool remove the bleeder and if water comes out the hole then the bleeder is plugged.
May 31, 2010 at 1:59 AM
