Weird sound when starting
2015 NISSAN SERENA
21,009 MILES • 2WD • AUTOMATIC
JAMES. U.
Yesterday when i started it, it made a weird sound. It sounds like a tuned up indicator or what. It kinda raises the engine. Then i went to the mechanic and he said that i need to drain the transmission oil and fill it again. I have just used this van for only a month. So we did, but it had the same sound when i start it again. The same mechanic did the same oil change with another Serena, and the same sound i had finished with that vehicle. I wonder how come it worked with the same car, same problem as i have, but didn't work for me.
Aug 22, 2020 at 3:31 AM
It sounds like what he was recommending wasn't the actual issue for the other vehicle. Maybe he got "lucky" with the other one. Can you get a recording of the noise so that we can try and identify what it could be?
Let's start with a recording and go from there. Thanks
Aug 22, 2020 at 7:27 AM
