1996 Nissan Serena starter motor
1996 NISSAN SERENA
CBLDTR
Electrical problem
1996 Nissan Serena 4 cyl Four Wheel Drive Manual
my starter motor wont even turn. ive already changed it once and the same things happened again.could it be electrical. these problems only started when i changed the live battery terminal
May 10, 2010 at 9:29 PM
BLUELIGHTNIN6
  • 16,542 POSTS
sounds like you may have blown a fuse or in line fuse when you replaced the battery terminal. check fuses , especially fuses to the Ignition / starter systems.
May 11, 2010 at 10:10 AM
