Nissan Serena
180,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
ELEUDUNAISKI
My Serena leaked gearbox oil at the radiator and my brother added normal ATF in the gearbox, the performance was bad and I searched on the net to verify the oil specs and remove all the oil from the gearbox and added atf synthetic as per specifications. Now the car is driving fine but when I reached 110km/h the gear change to a higher gear with full revs. From thereon the car pull very slow and had stop and after the gearbox oil dropped the car drive normal until you reach 110km/h and experience the same problem. Thanks
Jan 14, 2016 at 7:21 PM
HMAC300
  • 48,601 POSTS
scan fro codes first then check fluid level in trans if you can. then h ave a trans guy look at it.
Jan 14, 2016 at 10:59 PM
ELEUDUNAISKI
The fluid level is ok. Can you please explain scan for codes. Thanks
Jan 16, 2016 at 12:29 AM
HMAC300
  • 48,601 POSTS
a mechanic has to hook up a scanner to see if there are any electrical problems going to transmission and then work from there.
Jan 16, 2016 at 1:32 AM
