1997 Nissan Sentra Speedometer Stuck
FREDDYL
I have a 97 Nissan Sentra GXE sedan. The speedometer doesn't work. It's stuck on 25mph. The odometer and cruise control work fine. Is something wrong with the speed sensor?
Jan 15, 2006 at 4:16 PM
2CARPRO JACK
  • 11,533 POSTS
sounds like the speedo is broken
Feb 8, 2006 at 9:40 AM
Suggested Repair
The speedometer itself appears to be faulty and should be repaired or replaced. A speed sensor problem is unlikely because the odometer and cruise control still work.
Conversation Summary
The owner of a 1997 Nissan Sentra GXE reported that the speedometer is stuck at 25 mph while the odometer and cruise control work normally, and asked whether the speed sensor was at fault. The expert indicated that the speedometer itself is broken.
