1996 Nissan Sentra Rear Turn Signal Out
HOTLIO
I have a Nissan Sentra 1996 and I´m having problems with my right turnig light at the back. It does not light up even though the socket gets enough voltage to light a bulb. I know it gets voltage because I have used a tester to check how much voltage it gets.
[b:4cc3939a43]What could it be?[/b:4cc3939a43][b:4cc3939a43][/b:4cc3939a43][b:4cc3939a43][/b:4cc3939a43][b:4cc3939a43][/b:4cc3939a43]
Jul 16, 2006 at 9:59 AM
MIKEYBDMAN
  • 623 POSTS
Ok, you have voltage, but do you have a good ground? Im not sure how hard it would be to replace the light socket, but trying a new one may tell the tell. If they are easy enuff to pull off, try the left one in the right place and see if the lights work.
If a new light socket doesnt fix it, look for connection problems and ground issues.
Jul 16, 2006 at 10:43 AM
Suggested Repair
Confirm a good ground at the right rear turn-signal socket. If the socket is easy to remove, swap it with the left socket to see whether the bulb works. If a new socket does not fix it, inspect the connections and ground circuit.
Conversation Summary
The owner of a 1996 Nissan Sentra reports that the right rear turn signal does not light even though a tester shows voltage at the socket. The expert advises checking for a good ground, swapping the left and right sockets if practical, and inspecting connections and ground issues if a new socket does not solve it.
