O2 sensor will not cause the engine to quit on you
But by you driving that long way it may cause other damage to your car like the converter
And if it’s not overheating on you 40% it’s not bad
Make sure you check all your fluid tire pressure and E brake too before leaving
Take a look at the belts too
If not fixing o2 sensor you will spend more on gas
Good luck
SPONSORED LINKS
Wednesday, November 28th, 2007 AT 8:17 PM
