Nissan sentra 2001, 150k manual 5sp transmission. When i'm slowing down and I press the clutch especially when I go from 3rd gear to neutral the car dies. Check engine light is not turning on so I don't know what the problem might be. The car works fine when idle and accelerates smoothly as usual. The only time it dies is when I press the clutch after going 70/80 km/h and I press the brake to slow down (car is in neutral). Thank you for your help in advance.
ps. I changed spark plugs recently. Also could it be that my clutch is not working properly because it was replaced recently also.
Thursday, February 9th, 2006 AT 5:33 PM
