1994 Nissan Sentra Battery Dies
SPLIT082004
i have a 94 Nissan sentra. it has about 140,000 miles on it. i have recently installed a new battery and alternator. as i am driving down the road, the car will die. i can charge it up and it will run for about a day. what can i do to fix the problem. i have also checked all the fuses.
Mar 7, 2006 at 10:01 AM
FISHERMAN
  • 937 POSTS
first find if something its draining your battery, like a light... turn off the engine, close the doors and turn everything off then disconnect your battery positive cable and connect it right back but check if you see an "spark" coming out off the contact.. if so, you have something taking the power out...
also be sure that your alternator its working good.. sometimes fail even new.
Mar 7, 2006 at 1:29 PM
THSIUNG
I would check the alternator to see if its installed right. You should bring the car back to the mech who install it for you.
Car are not meant to be operate on battery power. If the battery is new than its probably something with the alternator.
I would bring it back to the mech, sounds like it wasn't install right.
Mar 14, 2006 at 6:41 AM
Suggested Repair
Check for a parasitic battery drain with the engine off and all accessories off, and verify the new alternator is correctly installed and actually charging. If it was recently installed, have the installer recheck the alternator and charging system, since a new unit can fail or be installed incorrectly.
Conversation Summary
The owner of a 1994 Nissan Sentra with about 140,000 miles says a new battery and alternator still leave the car dying while driving; after charging, it runs for about a day. All fuses were checked. Experts recommend testing for a battery drain and confirming the alternator works and was installed correctly, including returning the car to the installer.
