2004 Nissan Sentra Shifter Stuck in Park
WHEETZOID
I have a 2004 Nissan Sentra,1.8L automatic transmission, with 90,000 miles on it. I just drove it to the store, When I came out of the store, I could not get the shifter to move out of the Park position. Of course, I already tried firmly depressing the break, and the car runs perfectly otherwise.
The steering wheel is not locked. But I do hear a 'clicking' sound near the ignition key, everytime I push the button (to shift) on the side of the shifter. The button will not totally depress. I need to know how to either bypass this mechanism or to fix it. Please help!
Oct 29, 2007 at 5:46 AM
2CARPRO JACK
  • 11,533 POSTS
there is usually a button or key slot near th ebottom of the shifter to by-pass the lock mechanism. Might have a small cover over the slot.Other than that, you will have to take the console apart til you get to where you need to be
Oct 29, 2007 at 5:50 AM
Suggested Repair
Look for a shift-lock override button or key slot near the bottom of the shifter, possibly under a small cover, to release the lock. If that is not available, remove the console to access the lock mechanism.
Conversation Summary
The owner of a 2004 Nissan Sentra automatic could not move the shifter out of Park after a short drive. The brake was firmly depressed, the engine ran normally, and the steering wheel was not locked, but the shifter button would not fully depress and a clicking sound was heard near the ignition. The expert said there is usually a covered button or key slot near the bottom of the shifter to bypass the lock; otherwise, the console must be removed to reach the mechanism.
