2008 Nissan Sentra Brake Lights
51,000 MILES • 4 CYL • 4WD • AUTOMATIC
SPERS222
How do I replace the back brake light on my
Sentra
Oct 25, 2010 at 7:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
This is for Nissan Sentra Models 2007-2010.
1. Open the trunk and remove trunk liner by first removing popcap black button which fastens the liner. Then pull away liner from metal.
2. Notice two white protective plastic spikes covering 2 screw threads with 2 small bolts. Remove white protective spikes manually or by prying them off of their screws and proceed to remove bolts.
4. Pry away entire brake lamp housing from the exterior of the car in swinging door motion towards the sidepanels of the car. Dont pull too hard or let it hang as this may damage wiring - support lamp housing in place.
5. Replace lamp by manually pulling it's housing out of the lamp and then pulling the bulb itself out of socket and inserting new one
Oct 30, 2010 at 6:56 PM
