I am noticing a really annoying high pitch belt squeaking noise. I'm not sure why its making the noise, so i took it to Nissan if they can help me out with this problem, and all they said was that the belt could have gotten wet, or there was too much moisture in the air causing this to happen. But the belt can be both wet and dry and it still makes the same squeaking noise. I was satisfied with answer i received at Nissan so i took it to my mechanic and he tightened up the tensioner. But it still makes the same squeaking noise everyday. The car has almost 83000 km on it and it has been through 2 serpentine belts. I was wondering if you could help me figure out why the car is making the noise.
Thanks Fawwaz
Thanks Fawwaz
Jan 24, 2009 at 12:48 AM
