2004 Nissan Sentra emissions leak
10,200 MILES • 6 CYL • FWD • AUTOMATIC
CEALRYAN
why would a dump valve be used?
Aug 10, 2009 at 2:33 PM
STEVEW84
  • 673 POSTS
What is the problem you are having?
Aug 11, 2009 at 5:45 AM
CEALRYAN
I am just trying to understand the problem with my car and the solution that was done to my car, 200.00 dollars later. A dump valve was put on a charcoal basket. I guess it needed replacing. Engine soon light came back on, I took it back to the guy that is dealing with it for me. Now I'm told not the right gas cap. Apparently clicking this one 3 times is not offering enough weight to not make it leak? Does any of this sound remotely correct to you?
Aug 11, 2009 at 7:23 AM
STEVEW84
  • 673 POSTS
First, what is the code number? If it is a reputable shop then it should be on your receipt or the advisor told you.
Aug 11, 2009 at 10:34 AM
CEALRYAN
I was not given a code. And I am not doubting the guy. He is pretty good. I am just trying to understand what he is doing. I had a hose replace this past year that had to do with my gas tank. He also informed me today that the return line is also new , because I asked if there could be a crack in the return line. He wants me to try another cap. He said what is happening is that each time something is done, a different number shows up, and they are going to try the cap to see if that works to keep the light off. If it doesnt , they are going to do"smoke thru the car" to see where it comes out so they can find the possible hole , if one. Does any of this make sense? They told me some of these cars are sensitive to emissions leaks. Even a pin hole. By the way, Thank you for responding.
Aug 11, 2009 at 12:23 PM
STEVEW84
  • 673 POSTS
If you have the code(s) then I could explain to you what is going on and what he is probably testing. I can explain to you how the EVAP system works, but w/o the code then I can't tell you what he is testing and why.
Aug 12, 2009 at 12:10 AM
CEALRYAN
[quote:7970790298="stevew84"]If you have the code(s) then I could explain to you what is going on and what he is probably testing. I can explain to you how the EVAP system works, but w/o the code then I can't tell you what he is testing and why.[/quote:7970790298]
O.K. Thanks.
Aug 12, 2009 at 2:42 AM
