2003 Nissan Sentra Overheating
105,000 MILES • 4 CYL • 2WD • AUTOMATIC
SMCHAIREZ
My car has started to overheat.I am losing coolant through the resevoir overflow. I have replaced the radiator cap and the thermostant. I have checked the oil and it looks fine, no milky residue. The heater works for the first couple of minutes then blows cold air.
Oct 1, 2008 at 12:02 AM
2CARPRO JACK
  • 11,533 POSTS
Have it chemical tested for a blown head gasket.If the head gasket is bad, it can displace the coolant with air from the combustion chamber and do as you describe, it doesnt have to have milky oil to be bad
Oct 1, 2008 at 12:52 AM
