2003 Nissan Sentra Loss of Coolant
118,000 MILES • 4 CYL • 2WD • AUTOMATIC
SRBOJONNY
I have a 2003 Nissan Sentra, a month and a half ago my car was showing smoke out of my front defroster, I put stop leak in it,filled the radiator-it was fine. Two weeks ago, all of a sudden my car started running hot, I had no coolant in it at all, and my check engine light came on. The code said that the engine had run hot. I filled the radiator again,replaced the radiator cap and the light went off. Now, I had the same problem, I had no coolant in the reservoir and my check engine light came on again. I filled the radiator and everything, but I cannot find a leak. There is no liquid under my car, or under the hood, my floorboard is completely dry. Can any one help me?
Apr 16, 2009 at 11:03 AM
BUDDYCRAIGG
  • 2,262 POSTS
you could have a blown head gasket and you are blowing the coolant out the tail pipe while you are driving.
Apr 16, 2009 at 3:01 PM
NJXXXJON
  • 5 POSTS
[quote:ae5b9959e5="srbojonny"]Engine Cooling problem
2003 Nissan Sentra 4 cyl Two Wheel Drive Automatic 118000 miles
I have a 2003 Nissan Sentra, a month and a half ago my car was showing smoke out of my front defroster, I put stop leak in it,filled the radiator-it was fine. Two weeks ago, all of a sudden my car started running hot, I had no coolant in it at all, and my check engine light came on. The code said that the engine had run hot. I filled the radiator again,replaced the radiator cap and the light went off. Now, I had the same problem, I had no coolant in the reservoir and my check engine light came on again. I filled the radiator and everything, but I cannot find a leak. There is no liquid under my car, or under the hood, my floorboard is completely dry. Can any one help me?[/quote:ae5b9959e5]
Is your oil Milky? .....Is the smoke coming from your exhaust pipe REALLY bad?
Apr 18, 2009 at 2:43 PM
