2003 Nissan Sentra First It Overheated but now its dead.
78,000 MILES • 4 CYL • FWD • AUTOMATIC
WARRIOR0187
I was heading to work one day and while on the highway i saw thick white smoke behind, checked the heat guage....HOT. Puled over and had it towed back home. The radiator was cracked. Changed radiator, thermostat, even water pump. Still overheats. Nex day it wont even start. It tries to crank but it wont turn over. What could it be?
Dec 29, 2007 at 3:36 AM
  • 75,988 POSTS
Could be hydrolocked-remove all sparkplugs and crank engine over see if coolant comes out if so you got a problem with the headgasket/crack head or block.
Dec 29, 2007 at 3:44 AM
